daredevil95
- Oct 21, 2012
Hi, My passenger window stopped working, the widow will go down but, will not go up. Ok, checked power to the switch and power going up and down, everything checks out ok. So, I bought a new power window motor and plugged it in before installing it into the door, the motor will turn on/spin going down but, will not spin/turn the other direction.....same symptoms as the old motor, I also bought a new switch for the passenger door and still, the same condition exists. So, I know the new & old switch is getting power and sending power in either direction, what is else could I look at that will cause the problem, I'm thinking maybe the drivers door window switch may be a problem and I will buy a new drivers door switch in the morning, also, maybe I may of gotten a BAD new motor, I will probably pull off the driver's door panel and plug the new motor on that side to see if it spins in both directions. In the meanwhile, does anyone have any ideas or suggestions on what else to check or suggestions and/or familiar with this issue??
