D DarthBuick I Win even in your dreams. Joined Dec 22, 2014 Dec 24, 2015 #1 Is there supposed to be a gasket or seal on P.S. reservoir cap? Mine leaks around the cap during hard acceleration
D Dhos1 Self-tuning wanna-be Joined Apr 14, 2012 Dec 24, 2015 #2 Mine does not have one, not sure if it should or not..how full is it too where it leaks?
D DarthBuick I Win even in your dreams. Joined Dec 22, 2014 Dec 25, 2015 #3 It is filled to normal level and it leaks from the cap. The seal is just plastic to plastic so I will make a gasket and see if it helps.
blackazz Not a Gn TurboBuick.Com Supporter! Joined Sep 1, 2008 Apr 24, 2016 #4 DarthBuick said: It is filled to normal level and it leaks from the cap. The seal is just plastic to plastic so I will make a gasket and see if it helps. Click to expand... I'm having the same problem.what did you finally do to eliminate this problem
D DarthBuick I Win even in your dreams. Joined Dec 22, 2014 Apr 26, 2016 #5 blackazz said: I'm having the same problem.what did you finally do to eliminate this problem Click to expand... Yes it did help
K kjizzle Broken Joined Nov 4, 2007 Apr 26, 2016 #6 Are you sure it's not cracked or something? Sent from my LG-H811 using Tapatalk
blackazz Not a Gn TurboBuick.Com Supporter! Joined Sep 1, 2008 Apr 26, 2016 #7 Mine is not cracked.it just comes threw the threads.an down the sides
K kjizzle Broken Joined Nov 4, 2007 Apr 26, 2016 #8 Ouch. That's a simple fix, then. I'm glad it worked for you. Sent from my LG-H811 using Tapatalk
