dragway Member Joined Nov 6, 2011 Oct 6, 2013 #1 I am looking to buy a power logger but I was told that you need a minimum of 50 lbs injectors is that correct. Also do you need a wide band o2 ?
N notacarlo eggs are liquid chicken Joined Jan 7, 2004 Oct 6, 2013 #2 The only minimum there is....a factory ecu. Posted from the TurboBuick.Com mobile app
N notacarlo eggs are liquid chicken Joined Jan 7, 2004 Oct 6, 2013 #3 No WB02 needed. Posted from the TurboBuick.Com mobile app
dragway Member Joined Nov 6, 2011 Oct 6, 2013 #4 I have the factory ECM in vehicle still so it should be fine to hook up then?
N notacarlo eggs are liquid chicken Joined Jan 7, 2004 Oct 6, 2013 #5 Yup. Just get some good goo cleaner for the end of the main board, and a laptop you're all set. Posted from the TurboBuick.Com mobile app
N notacarlo eggs are liquid chicken Joined Jan 7, 2004 Oct 6, 2013 #7 No problem. Learn and enjoy! Posted from the TurboBuick.Com mobile app
H HouTX87 Active Member Joined Nov 21, 2011 Oct 6, 2013 #8 dragway said: I am looking to buy a power logger but I was told that you need a minimum of 50 lbs injectors is that correct. Also do you need a wide band o2 ? Click to expand... You must be thinking of the 6.1 wideband chip which requires minimum 50lb injectors.
