m3x1c0
Bad luck Buick
- Jun 16, 2014
Simply put: I have a log showing me going 89 mph at 19psi in Park/Neutral. When I put car in reverse it doesn't show the checkmark by the P/N but then in drive goes back to Park. Switch works fine, reverse lights work and the Scanmaster knows I'm in park (good for changing chip settings with car off INT 12 for example.) Not sure what could cause this. PLC on my laptop is up to date. Not sure on firmware in the PL haven't figured out how to check that but these features worked fine up until recently. Also do not see any TCC lockup. I'm a total noob and don't know if I could tell it was in lockup unless the PL shows it. Steve said he didn't feel it lockup though.
Any ideas how to fix this?
