power door lock relay.....
NOTSOFAST
it seems that only my pass side door lock switch works. I replaced the driver side door lock switch , but it still wont lock or un=lock the doors. does the relay run both, or does it split driver amd pass? And where can I locate one as no auto stores carry them?
earlbrown
runs with scissors
It could be power getting to the switch, the switch it self, or the wiring between the relays and door. Only way to know for sure is to get out the meter.
vader87
Protected Freedom for 27 years! Thank a Veteran!
RmvBfrFlght
The door lock wires like to break inside of the rubber accordion that is between the a-pillar and door. Sometimes you can pull back the accordion and get to the wire in question. Yes, it is a pain.
RemoveBeforeFlight
