Just as an FYI to those of you who have bought Poston headers. Make sure they are leak free before you put them on.
I just got my second set from them that leak right out of the box.
The first set had flanges that were not flat and an incomplete weld on one of the exhaust tubes. Looked like whomever welded it missed the joint and welded up on the tube. Left about an 1/8 to a 1/4 leaky joint. It was on the passanger header (center tube wher the tube meets the colletor pipe).
The set I got yesterday (set #2) both leak. The drivers side has a pin hole leak in the same spot as the first set. the welder did not over lap his start and end points and left a little hole. The drivers side header leaks at the head flange to tube weld.
I taped up all the holes and applied few psi air of pressure to the headers, then sprayed them with soapy water. They blew bubbles like crazy.
This is not a bash on Postons. They are trying to get me a good set and say they are going to work with their supplier to fix the issue. Only problem is they only have one set left in stock. Hope the ones on the way look better then the last two.
