buickpower
polytetrafluoroethylene
- Jun 27, 2003
My car has been leaning out pretty bad, like 730mv on 15psi! I am running a poston fuel pump which is apparently a modded syclone pump, and is essentially new. I also run 37lbers and fp of 47 line off (new accufab). I had tried a bit lower pressure ~45 with the same end result. My translator is also on the max rich WOT setting, 14%. But still the fuel pressure gauge does not even go as high as it should (62) it hits mid 50's, and decreases from there! I have verified that the pump is getting good voltage 13.9 at the back of the car where the pump plugs in, and that the alternator is getting good voltage during the run. I even tried changing the fuel sock and filter up front, to no avail.
My question is, has any one else had similar problems with this pump? It was supposedly rated at 4-600hp . Also, would dropping the fp down to the recommended 42 line off allow the pump to deliver any more volume because of the lower pressure, or should I just trash this pump like i am thinking?
