i need to datalog an extra IAT and an extra MAP sensor.....
i can artificially create my own 5v source but i figured this would just be easier
the reason why i need a 5v source for the IAT sensor is that my datalogger doesn't datalog thermistors. So, i know, you are asking yourself if it can't datalog thermistors why are you bothering using an IAT and messing with the 5v source?
well, thanks to my friends on the DIY_EFI email list they explained to me that i can install a bias resistor inline with the signal wire to the IAT. Then supply a 5v source to the sensor and then DATALOG that 5v source as it changes with the resistor
Then all i have to do is do a couple tests with a IAT sensor, thermometer, and some hot water.
Lastly, configure the software (Xv = X*) and then wala, i can datalog my IAT readings
I was also told that the IAT sensor's thermistor isn't a linear curve but linear at first and then curves at the end. I am not worried about this, it will be close enough for my purpose
Craig, since only the TPS and the MAP receive the 5v source...you think it would be ok to tap into that 5v supply for 2 more sensors? I mean i dont think the load could be that great
thanks for your help
edit: As you already know, The IAT has its own signal coming from the ECM. I just looked at my modified pin_out list (i installed a single 48pin bulkhead connector to clean up wiring and had to make one) and looked and confirmed what you told me.
here is a nice link to the specs on the GM IAT sensor:
http://forum.aempower.com/bbs/download.php?id=312
