if you did, you would loose your rolled fillets that make the crank different from the NA cranks. You also would have to find different rods to use since you'd be reducing the rod end diameter from 2.00" to whatever you offset grind to. While its theortically possible, it would be highly inpractical and you'd be better off buying a stroker BMS forging and some wide journal Carillos.
