well i am working on the new race car, and decided to use por15 on the cage and chassis, this stuf is absolutly amazing, brush on leaves a finish without any brush lines or orange peel, shine is woutstanding, and hard as a rock, i bouced a 9'' centersection off of the cage, all it did was chip a very little piece, i painted the tail steel on wed, cleaned it with canned brake cleaner and carb cleaner for a 2nd coat, and that stuff would dull any auto finish, all this stuff did was clean up to an even better shine, did not affect the stuff, it can be put on engines, good to 500+ degrees f and it dries by absorbing moisture so it has hardly any smell, the only prob is get it in small quantities, because if you get moise air in the gallon can as i did the whole can will react and in a week you will have a solid can of paint, this stuff is better than all 2 part paints i have used, civilian and military and like i said the finish is out of this world. i recoment it to everyone, especially in an engine compartment, and they have a specifiec color for chassis, check this stuff out people
Grant J Farmer
Grant J Farmer
