one of my cars has developed a weird pop on acceleration. It happens when you punch it from a stand still around 3000 to 3500 and around 8-10 PSI of boost. I would have some better data on it but my laptop just took a dump in the middle of recording it with DS. Sometimes it will do it when you punch it while going, but almost never does it when you ease into it. Am currently running a max of 15 PSI. When it pops I only get a small amount of knock, around 3 or so but that is really bad since I like none at all, and the boost will jump momentarily at that point.
Stuff I've tried since it started:
Replaced coil pack(should have a new GM module Thurs.)
New Plugs and Wires(plugs gapped at 35, then to 33)
Different chips and computers
Running with DS not installed
Reseting TPS and IAC
Fuel Preasure verified at 42 PSI vacuum line off and around 58 PSI at 15 PSI boost
New fuel filter
Checked grounds and Positive Bat cable
Checked CAM sensor setting
Traded MAF's with a known good one.
At idle everything looks good:
TPS=.42 MAF=7 BLM Cell 0=126 IAC=15 Temp.=161 O2 very active.
WOT as far as I can remember:
TPS=4.69 MAF=254 BLM Cell 15=134 Temp 163 O2's 790-820
Boost =15
Car= 87, TA-49, Big neck IC, 50# injectors, Lubrant street chip, Adj. reg, KN cone filter, Walbro 307 and hot wire kit, cat back Hooker exhaust w/test pipe, RJC powerplate.
Anyone have anymore suggestions? I should have a new notebook by the weekend to record some data and probably wont try it but once when I get the coil pack on Thurs to see if that clears it up before I get another notebook to keep tabs on everything.
TIA
New fuel filter
Boost =15
TIA
