Since I am upgrading to a 4.1 litre "291" block powerplant, it has been suggested that I use poly motormounts instead of the factory sponge rubber mounts and a torque strap. I was considering the poly motormounts made by HR Parts and Stuff as sold by Johns Performance:
TT/A Poly Motor Mounts 0263
Working in cooperation with HRpartsNstuff we worked well over a year on this project. These Poly Motor Mounts are for the 89 TTA's with PRODUCTION 3.8 V-6s ONLY. They can also be used for engine swaps with prod. 3.8's in other F-body chassis (Camaro/Firebird/Trans-Am). This is a COMPLETE KIT, including new motor mounts, new frame pedestals (frame pads), isolation pads, new hardware, and a custom wrench. These come with NEW softer custom poly bushings installed, designed especially for the TTA's. These are designed for daily driving and off road use, down to low 10's in the 1/4 mile, with great results
Has anyone used these particular motor mounts? Is there anyone else in the aftermarket that makes a motor mount for TTA's?
Mark
Mark
