Point and Click BLM adjustment on Power Logger not working
Bill_Ritter
Plays with Fire
I have the TT 6.1 wideband chip and powerlogger installed properly, but I cant get the point and click function to work for adjusting the 8 BLM cells. I CAN adjust them with the old gas pedal method and turning the key on/off etc.. but its annoying.
What do I need to do to get this to work?
I'm using this on a Toshiba laptop with windows 7. Everything else works as it should with the Powerlogger and wideband etc. Just not this function
Start PLC
Hook up the USB cable and turn the key on.
Go to Tab F1.
Press about PLC
Tell us everything you see
Aminga... I'll do that shortly when I get home.
Ryan, no I haven't reflashed anything. Im not sure how to do that. I'll look into that as well.
That what I was getting at. To use the point and click adjustments the PL has to be running V 1.3 firmware or better. So on that screen click reflash it will ask for an update file. You want to use PL030.s19 or better
