Okay here we go....
1. Can lowering your boost at the wastegate effect how fast you can build boost at the line? I went to the track on Friday, with the boost set VERY conservatively to tune. I tried to build boost at the line and it wouldn't. I sat there for a while after the light turned green, but I could only get it to about 2 lbs. Boost was fine under WOT.
2. Can a fouled O2 sensor cause this? I triggered a code 13 not one hundred feet out of the track on my way home from using race gas.
3. Can a fouled O2 sensor cause knock retard? While driving home (not in traffic, but it was very hot, still had the fouled O2 sensor in until the new one arrives, 93 octane) I leaned on the car a little bit to merge into traffic. I barely registered 0 on the boost gauge, and I had 3 degrees of knock retard. The car was fine on my ride in to work.
I truly appreciate any and all opinions, suggestions, ideas, etc.
Kristi
Kristi
