FYI, from looking at the pics of the bottom end that is a BMS forged crank not a billet and those aren't Carrillo rods either. I don't believe Callies ever made a crank for a Buick V6. Someone correct me if I'm wrong as there were a number of crankshaft manufacturers finishing the BMS forgings back in the day. Without harping on the obvious that block is done, you should check the other side as it's probably starting to crack there also. I actually gave one away that was in better shape than that so my buddy could use it to mock up his race car.
Good Luck
Neal
Neal, thank you for all you advise!
Well, if it is a cast BMS crank, how well do you think it will hold up?
How much power HP can these cranks reasonably handle in an off center Stage II 4.1? (I don't know if it's been cut because I haven't taken anything apart yet)
I don't have an exact H.P. goal yet, but I'm building the car to TSL rules.
The frame is out of the car right now because I'm detailing the under body and frame. I will have the frame back in within 2 weeks and set up the rest of the suspension and drive-train.(TH-400, chromoly driveshaft, ford 9", HR Parts rear suspension, chromoly roll cage, new poly bushings....)
I want the car to run HARD and be as reliable as possible. It would be great to run a heads up class! Thats why I wanted the Stage II motor.
I want to thank everyone for their helpful comments and concern. You guys have already helped me tremendously! I can only hope the advise keeps on coming, because I'll have a few more important decisions to make.
A few decisions I've already made based on the responses you guys have made are...
1. I will not be returning the engine. (there's just to many necessary parts that were included in the sale that would cost me a fortune to buy individually)
2. I'm going to have the seller buy me a stage II 4.1
3. I will need pistons
4. I need to check the crank to see if it's been cut.
5. I need a beer! :biggrin:
