ITSAV6 It's my Granny's car! Joined Nov 13, 2001 Sep 26, 2003 #1 Should I take the extended snubber off and put stock one back on? I pull 1.75 60ft launching@1psi. Launching @higher boost it will hook for a couple of feet then spin. Is it the snubber rebounding the axle and unloading the tires?
S Slow91z Turbobuick.com Helper Staff member Joined Aug 7, 2003 Sep 26, 2003 #2 Take it off and try it...if you go faster, then leave it off.
I idaho gn behind the learning curve Joined May 25, 2001 Sep 26, 2003 #3 in my exp a pinion snubber is not nessicary shawn
