toomanymodz
- Oct 14, 2009
When I purchased my adjustable uppers, I set the pinion angle to about 3 degrees. After going to the track and pulling some 1.47 sixty foot times, I was under the car and decided to re-check it. It appeared to have changed, so I turned the adjustment several turns (maybe 5) to shorten the upper control arms. They now measure 10.75 inches. I believe stock length is 11.125.
Either I didn't have the pinion angle set correct to begin with, or is it possible to bend the frame where the upper control arms attach to?
I have since purchased a digital angle meter, so at least I can set it more precisely this time. But it's on the back of my mind, did I bend something. ?
I have these reinforcements, I would think this should be adequate for my horsepower level.
