I've got all the parts out save the internal engine components. Feel free to make offers on anything. For those of you who sent me lists of the parts you wanted before, please resend them as I lost my messages when vbulletin was updated.
Ignition and Electrical
Brand new Computer controlled coil ignition (CCCI) module and coil pack $225
MSD DIS 4 with GN adapter $200.00
Accel 300+ 8.8mm wires (500 miles) $50
New Impala 140 Amp alternator (500 miles) $100
Motor (block and accessories)
3.8L Block is cracked so I will be parting the internals out also:
ARP head studs
New water pump (500 miles) $30
RJC aluminum pulleys (alternator, crank, and water pump) $100
Buick Motorsports valve covers $75
T&D 1.65 roller rockers $300
RJC Valve cover spacers for roller rockers $65
Crane Cams lifters and 120lb. Double springs $200.00
210-210 camshaft
.30 over TRW pistons
RJC engine girdle $350
Hooker Dual Stainless steel exhaust
Port & polished 4.1L heads with bigger valves $600
Port and polished intake manifold $150
RJC Stocker Power plate $40
ECM & Sensors
Accel SFI (rare sequential version of DFI) 6.0 with harness adapter with 2 & 3 Bar MAP sensors $650 shipped
cam sensor
2 new crank sensors
knock sensor
oil temp sensor
water temp sensor
Fuel System
Accufab billet aluminum adj. fuel pressure regulator $75
Sumped gas tank $150
Turbo, Exhaust, and Intake
Jay Jackson 62mm Throttle Body 86-87 $100
Delta Wastegate (500 miles) $100
Turbonetics T60-1 Ceramic Ball Bearing Turbo (only 500 miles! Exhaust housing needs to have some welding done) $500
Atr race turbo headers w/ ceramicrome coating (non-log style / needs new crossover pipe) $150
Polished up-pipe and Tial BOV (with couplings and clamps) $250 shipped
TurboXS dual stage boost controller
Other Items
New black carpet $150
Metco billet aluminum Adjutable Upper and Lower control arms $350 for the set
A pair of airbags $50
ARP head studs
210-210 camshaft
ECM & Sensors
cam sensor
2 new crank sensors
knock sensor
oil temp sensor
water temp sensor
Fuel System
Other Items
