9 9SECVSIX Member Joined May 25, 2001 Jan 13, 2012 #1 Any suggestions on doing a black out on the white line bumper strip, the TR one was all I could find. FWIW it's a new piece. thanks B.
D Danster Senior Member Joined Nov 26, 2001 Jan 13, 2012 #2 I believe all are the same. To remove the white line, try using a lacquer or paint thinner to remove the white from the bumper strip. Maybe someone will respond on what they used that may have been better than what I mentioned above. Dannyo
T turbojd Well-Known Member Joined Dec 27, 2005 Jan 13, 2012 #3 Danster said: I believe all are the same. To remove the white line, try using a lacquer or paint thinner to remove the white from the bumper strip. Maybe someone will respond on what they used that may have been better than what I mentioned above. Dannyo Click to expand... X2, lacquer thinner works to remove the white strip.
M MSDGN Active Member Joined Jun 8, 2001 Jan 17, 2012 #6 Denatured alcohol and some Q-tips...have done many that way...
T turbonut85 Rarely used member Joined Apr 11, 2008 Jan 17, 2012 #7 Laquer thinner here...worked great.
Phoneguy Cometic HG stress tester Joined Aug 27, 2002 Jan 18, 2012 #8 Someone posted on here before that compressed air will take it off. Bryan
B Bruce Urie The Ventures,CCR forever! Joined Dec 30, 2006 Feb 19, 2012 #9 turbonut85 said: Laquer thinner here...worked great. Click to expand... That was me......it's what I did and it worked just fine. I used the wrong quote......I meant that I used an air compressor to remove the white line...sorry. Bruce '87 Grand National
