That was with C16???I like 9.1 to 9.5-1. I have run as much as 10.5-1 but as Don hit on, the higher compression will make your tuning window smaller. I tune a local turbo car with 12.2-1 and 22psi of boost and it's very touchy. We are trying this because of the small turbo limitation in the class keeps the boost under 25psi. I feel I have to pull the timing back so far that I could make just as much power with 10.1 and more timing. I'm not sure going higher than 9.5-1 on gas has any gains because you have to run less timing to keep cylinder pressure in check.
My answer. 9.1-9.5-1
