Has anyone had an "optimum" alignment done for 1/4 mile use? For example, having the front end of the car jacked up a bit to simulate the "nose up" attitude while blowing down the track, and having the car aligned that way? If so, what specs did you use? I am having the PS front UCA bushings replaced and the front end is in need of alignment, and I thought I'd try to get the "trick" alignment done at the same time. The shop told me that if I could get some specs that would be great; otherwise, they'd just use the OEM specs "in the book". The car has no front sway bar and 90/10s up front.
Thanks for any & all replies!
Regards,
Morgan
'87 GN 11.1s...getting there.
Regards,
Morgan
