fastdavedk, the issue you are referring to is a charger-related issue and not specific to Optima. In fact, some companies will void the warranty on their battery if it is found to be discharged below 10 volts. The problem is that many chargers will not recognize or charge any battery that has been discharged below a certain voltage level (usually around 10.5 volts). Wiring the discharged battery in parallel with a charged battery allows the charger to “see” a battery and deliver current to the discharged battery. We created a Tech Tip video on our YouTube channel (OptimaBatteries) that also explains this procedure.
I can't speak for other AGM battery manufacturers, but most standard chargers will work just fine on Optimas. AGM-specific chargers are preferred, but “gel” or “gel/AGM” charger settings should be avoided, as they will not fully-charge an Optima and could damage it over time. Our batteries can be charged at rates up to 10 amps, but if the battery gets hot to the touch or begins venting, charging should be discontinued immediately.
If a vehicle does not see regular use, a quality battery tender or maintainer is an excellent investment. When any battery is discharged below 12.4 volts and allowed to sit, sulfation begins to diminish both capacity and lifespan. I can't speak as to the mechanical benefits of periodically starting and idling a stored vehicle, but this practice may actually do more harm than good to a battery, if the alternator is not given enough time to replace the energy used during storage and starting. If anyone has any questions about our batteries, I'll do my best to answer them.
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
