I'm very excited to get that car into the type of condition I want. The guy who built it had over $66,000 in receipts WITHOUT the price of the car or any interior cage work. It's going to take me another 30K to get it where I want it, but when it is.....WOW!
Supra has the following done to it......The only thing stock is the main body and dash pad. :tongue:
Sound Performance 3.2L stroker
CP Pistons (custom)
Pauter Rods (upgraded carr bolts) (custom rods)
Clevite bearings
ARP main studs
Program Billet mains
Line honed block
Stock bore size
Fully polished and ported head (clearance for BIG cams)
+1mm Crower valves
Ferrea dual spring/retainers
L19 Head studs
HKS 272 Cams
Unorthodox Cam gears
Unorthodox Pulleys
BoostLogic crank pulley
BoostLogic Billet tension
SP Racing Intake Manifold
Wilson 105mm Throttlebody
SP racing turbo header T6
Tial 44mm wastegate
GT47-80mm turbo (polished and coated) T6
Virtual Works anti-surge turbo insert
Custom SP (chromed) 6” cold air intake
Custom cnc’d water neck (to fit large frame turbo)
Custom 5” SP downpipe (recirculated)
HKS racing bov
Fluidyne Supra TT radiator
Sound Performance 5 inch race Intercooler
Custom Virtual Works 4” intake piping
Virtual Works Upper and Lower Intercooler Strap
RPS Carbon/Carbon clutch
Custom 1pc steel driveshaft (cnc’d ends)
Virtual Works Driveshaft Loop
SP modded Toyota Oil pump (new)
Toyota waterpump (new)
Toyota P/S pump (new)
Toyota Timing belt (new)
Polished Valve cover
Upper radiator hard pipe
Upper Radiator Cooling Plate
Upper Radiator Show Plate
3 Intank Fuel Pumps.
Aeromotive Fuel Pressure Regulator
1200cc Injectors
SP fuel rail (dual feed)
Custom AN Fuel Lines
TRD LSD
TRD Sway bars
Cusco carbon rear strut bar
Tein Flex coilovers
Tein EDFC controller
TRD motor mounts
HKS DLI Twin Power Ignition
Blitz turbo timer
AEM EMS with 5 bar map sensor
AEM Tru Boost Controller
AEM Serial Gauge
FJO Wideband gauge custom mounted
TRD 10K Tach
TRD Steering Wheel
Trunk relocated battery
RMM front lip
Bomex side skirts
Pro EFI Engine Management
HKS Hiper Titanium Exhaust
Sound Performance CNC Drive Shaft
Brembo 14 Inch Big Brake Kit Painted Lambo Verde
Slotted front + rear Brembo rotors
Goodrich Stainless brake lines
HRE 597R 18X10 (275) front
HRE 507R 18X11 (315) rear
Mickey Thompson ET Street Radials rear (315/40/18)
BFG Gforce ZR front (275/40/18)
Clear Signal Markers
Smoked Side Markers
Smoked Taillights
C’s Short Throw Shifter
MVP Coated Aluminum Shift Knob
TTC Drilled Performance Pedals
10% Tinted Windows
New Carpet 33,000 miles
Custom Supra Black Floor Mats
Sparco Milano 2 seats
SP Rear Seat Delete
Boost Logic T6 Turbo Blanket
Powerhouse Polished Spark Plug Cover
TTC Polished Brake Cap
TTC Polished Washer Cap
TTC Polished ABS Relay Cover
Greddy Billet Oil Cap
ATI Lexan Spark Plug Cover
3M Clear Bra
All Bolts Switched to Stainless Allen Bolts
Lines Converted to Braided
Polished Fittings
Thanks for the other kind words gentlemen.
