Okay guys,
I need your help again, what is your typical speed secret/formula/recipe for making a typical GN run high to mid 12's on STREET tires (no DR's and no slicks) on PUMP 93 octane gas?
I WANT TO BE ABLE TO RUN HIGH TO MID 12'S ON STREET TIRES AND 93 PUMP GAS!!!:
To save you some time, here is what my car had on it when I bought it:
*Stock IC with Duttwiller neck
*340 Warlboro in-tank w/hot wire
*50lbs Injectors
*New Stock turbo
*ATR cat-back system (Pitbulls mufflers)
*D5 modified to stall between 2,600 to 2,800
*Trans has been rebuilt w/big servo, billet shaft...etc (with trans cooler)
*Translator plus w/Extender chip
*3" Impala SS MAF
*boost, knock, oil press and coolant temp gauges
*160* T-stat
*Boxed upper and lower arms
*Air bags on both Sides!
*Stock actuator rod is modified
*New dual steel timing chain
*New cam sensor
*New rear main seal
*New oil pump (oil press reads 30psi at idle when engine is warm, and 60/65 psi cruising)
*Coolant read about 170* to 180* cruising or in traffic
*Stock 215/65/15 tires
*All new fluids
*Car have about 28k original miles
***I just added a "test pipe" to the stock DP
***I made a homemade CAI kit
***The boost reads about 16 to 18psi when I stab it!
I have to play with the tuning (T+/extender chip) to dial her in further, DO I HAVE enough right now to accomplish this high to mid 12sec on street rubber and 93 gas goal? Or I'm I dreaming ?
Thanks.:smile:
*50lbs Injectors
*New Stock turbo
*3" Impala SS MAF
*160* T-stat
*New cam sensor
*New rear main seal
*All new fluids
Thanks.:smile:
