I moved this from the PCV thread to check response.
I now seem to have a problem again with my current ride (87 Turbo T) The longer it runs, it smokes blue at idle and sometimes at cruise. Leakdown is good at 4 % in all cylinders and I have my "trap door" breather on drivers valve cover. Funny thing is, all 3 spark plugs on pass side are a bit wet looking and oil on threads, but the drivers side were quite dry in comparison. These are M&A heads. The valve covers are definately not leaking down to the plugs. After valve cover removal, I noticed 4 of 6 valve seals on both sides had come off the guide and were going up and down with the valve. Funny thing was 2 were intakes and 2 exhaust on each side, so why are the plugs somewhat wet on the pass side only ? Anyone else experience this B-4 ? I removed the seals (they're new w/less than 500 miles) and compressed the metal ring tighter that holds them to the guide, and reinstalled them again...hopefully they will stay put ! This may have been my "blue smoke problem, but I still don't know why just the pass side plugs were a bit wet ? Anyone have any ideas ? I suspect the turbo could be a source of the smoke also, so I will eliminate it as a possibility if the valve seals don't do the trick.
Thanks for any comments ! Clem
