Is anyone using an external oiling line to the rear oil galley to supplement oil flow to the rear mains? My rear main bearings look to be somewhat starved for oil. I was rooting around on the Web and found mention of adding a supplemental oiling line in high HP application to help the rear bearing set live. If you're running one of these, what size line did you use and how do you go about plumbing it to the rear?
Thanks in advance,
Thanks in advance,
