I have finally cranked my new setup, and have an oil leak that appears to be between the pump housing and the extension plate for the longer gears within. (I'm assuming it blew the gasket)
I am using the TRW high-volume, high-pressure pump setup, that was written up in GM High Tech awhile back.
Questions:
Does anyone know what the stock oil pressure is, (should be), at idle, and above? (I very well may be pushing too much with this...)
Has anyone experienced this sort of problem when upgrading to this setup?
Does anyone have a suggestion for a solution or fix? Is there something that needs to be drilled or opened up to accomodate this additional volume/pressure?
My initial plan is to put a less stiff spring in the pump, but may even have to go back to the stock setup.
Any input would be greatly appreciated! Thanks.
Questions:
