what do I look for turbo shaft play/oil in the housing ? --------thanksTurbo oil seal is leaking.
what is a ps valve ? thanksYou could pull the downpipe back and look inside to see if there is oil. I can't think of any other way oil can get into the uppipe and IC.
chrisgarrett you have been a big help sir this forum is way ---thank youDo you have the stock setup with the ps valve cover venting into the turbo? This is a possibility.
https://secure.mysuperpageshosting.com/kirbanperformance.com/index1.htm
Do a search for product # 1580
