Oil cooler valve
Matone213
Hey all the oil cooler valve won't line up with the one on the pump seems like that lil lips are in the way
Dude, you might want to expand on your assessment. That bypass valve in the oil cooler sammich is sealed up and pretty much set in stone.
If you have access to the spring and inner workings, there's a chance you're about to be in trouble.
It's all in place just wanted to make sure i was putting back on correctly the oil cooler sammich I mean
Ive seen them loose and you can get a center punch and stake the alum around base to get the "tower" to be more secure.
