Just as the subject says. Took off the stock fpr tonight to try out a different stock one and now it leaks like crazy where the fpr meets the fuel rail.
Coat it with vasoline it will help in the install if you continue to have problems... also if you damage it, i think it is the same o-ring found on fuel injectors. HTH
