Hello everyone,
I need some advice. My lock up stopped working. I checked all the electrical, everything checks good.
I have a 200-4r setup with non computer control. Ignition voltage to NC brake switch to NO ported vacuum switch to positive side of lock up solenoid the ground side to NO 4th gear switch. I have power all the way to the solenoid and the 4th gear switch grounds with pressure applied. I went ahead and replaced the lock up solenoid while I had the pan off. No lock still.
Where should I go next? I'm guessing the clutch is smoked! Any other suggestions?
Thanks in advance!
Thanks in advance!
