B BLU Member Joined Mar 26, 2004 May 30, 2005 #1 When the fan kicks on it's very noisey, is that normal or is there a problem ? Thanks
B BLU Member Joined Mar 26, 2004 May 30, 2005 #3 Noisey enough to draw your attention to it, I just don't know how quiet it should be
N NJTurbo Simply The Best Joined Jun 22, 2002 May 30, 2005 #4 To be honest with you, the stock style fan set up on my past GN'S you could barley hear. Is is the hum that is loud, or is it hitting something etc. My Stage car has a black Magic fan, sounds like a jet taking off but keeps things very cool
S scottyb Spongebob Squarecar Joined Oct 12, 2001 May 30, 2005 #5 Noisey as in out of balance or bearings going bad? If so, I highly recommend an upgrade the Ramchargers dual fan (or equivalent). With that addition, My AC is an entirely new animal this year, and I haven't seen the water temp go above 173.
D duane cole New Member Joined May 18, 2004 May 31, 2005 #7 had same problem it was fan motor just change it delco number 15-8221 or GM 22062546
