noise at 2300 rpm
heidi
Has anyone had this same issue? Engine rebuilt but makes what sounds like a heat shield noise at only 2300 rpm. It happens in any gear or in park.
Does it do it with the accessory drive belt off? Does it sound like its coming from the bellhousing area? If so does it do it with the torque convertor unhooked?
i will try that. It does sound like its coming from the front of the motor. thanks i will let you know.
Check the intercooler brackets and be sure the belt tensioner isn't bottoming out
Hello Heidi...per my PM I have isolated a rattling noise at 2200-2300 RPM...I posted some vides of the noise. I went through many steps to diagnose, including belt tensioner inspect, getting the correct belt on to center the tensioner in operation, cerefully reviewing shifter/brackets/lines/exhausts etc looking for the noise.
http://www.turbobuick.com/forums/threads/rattle-noise-at-2200-2300-rpm-in-drive.411009/#post-3398373
I finally realized it was coming from my transmission. I did this as one day I mistakenly left the garage with the TV cable unhooked and the noise was gone. With the TV cable hooked back up the noise returned. I can move the TV cable adjstment and make the noise extremely loud (with the cable adjusted further from throttle) or very quiet with the TV cable adjusted toward the throttle.
There are many sources for ratttles that vary with engine speed, for me this one has alluded me for two years and two Hot Rod Power tours. I do not have the funds right now to go through the trans so I am just enjoying the car as much as I can until I can fund the trans work.
Thanks, I looked at your video and my noise is exactly the same. Its a horrible noise and sounds like its something bad.
