No start with new harness
aero_SS_national
So just installed my new custom harness from caspers ( 87 engine , emissions delete, dual fans setup, a/c setup, stand alone for it's new home 87 Monte Carlo) I rent a garage and was just informed that I have to leave asap which is really bad timing because now there not time to wire things up the way I would like. So now the goal is just to do whatever I have to do to get this thing running just to move it to another garage not far away so I figured I'd just wire up the ignition wires and fuse panel feed and leave the other things for another time (wiring for tcc switch , vss buffer, check engine lamp, tach and ac trigger) the car cranks but does not start fuel pump is working I have 12v at the injectors with key in on position ( normal? ) power to ccci but no ground to black/red wire while cranking ( normal?) my question is would any of the wires I haven't connected cause the car not to start ?
