before someone says it I know this has been a common question and I looked at ally of threads but still searching for an answer. Long story short I pulled the motor over the winter and put new heads on it as well as bigger injectors (120's) a modded ECM for e85 with TT chip.
I have tested injector puls with noid light and it checked out good. I have swapped on 3 different ignition modules (coil packs) and still no spark at all. I put a brand new crank sensor on as well as another spare I had laying around and checked adjustments several times. Also swapped in another modded ECM I had sitting here and nothing.
When cranking car my scaNmaster registers 300 RPM.
Where else do I go???
