GNBRETT
Pelennor Fields
- Feb 8, 2004
It Seems That When Brutal Horsepower Is Applied To The Tr Is Has A Tentancy To Twist A Little With Evidence Of Frame Twisting On The Car Consisting Of Small Crinkles Causing The Paint To Flake Off. For A Street Car With A $6000 Paint Job That Is Not Good! Does Anyone Know Of A Set Up That Would Keep A Car Together (straight) Without A Bar Or Cage.
What I Mean By This Is There A Way To Strengthen Up The Body Of The Car Without Adding A Bar Or Cage And Cutting Up The Interior To Be Visible From The Outside?
Is There A Way To Add Support To The Car Via The Trunk Area Alone That Will Keep The Car From Twisting Without A Visible Cage. Basically, If One Was Interested In The Sleeper Appearence Could A Car Be Strengthed Up Enough To Prevent Frame Twisting Without being Visible From Outside The Car?
