No Heat
Sarah99gxe
Finally got my Turbo
Recently my heater started blowing cold air. What's the first thing I should be looking for/to replace?
83 Regal T-Type
rebuilt stock motor approx. 2000 miles on it
Thanks,
Sarah
Well Sarah, only 3 things would give you a problem. The blend door lever, the heater control valve, or a stopped up heater core. First check the heater lines and see if BOTH are hot. Then see if the heater box is hot. If both are true then the blend door lever is broken. If lines are cold then either valve or or core is the problem. Good luck.
pivot on temp door
i have pretty much same problem sarah is having i have checked cable,hoses, heater core , all check out i think i traced down to a broken door in heater unit. one ? i do have for you guys is the pivot arm on these things are they pressed on or can u just pop them off i tryed removing it with a small trim tool but no luck looked like it was going to break off any advise would help thanks
