It was running and just stopped one day, I have replaced the fuel pump, fuel pressure regulator and I still have no fuel pressure! I am suspecting it could a bad injector, but if 1 was bad, i would think I would get more than 2-5psi, it was doing this before I replaced the pump & regulator. I have a Hotwire kit, checked relay & fuses and all are good, have power. Could it be a bad injector or what else? Could it be a bad ignition module or? just starting to think it may not be a bad injector? When powered on the fuel pressure gauge may jump 2-5psi and drop immediately and it did this with both the old & new fuel pump & regulator. Just looking for some help/direction of where I should trobleshoot next.
