Te-60 turbo, stock wastegate, 60lbs inj. Ic cooler, checked the wastegate and seems to be good, took the down pipe off, and checked the puck, and sealing, no exhaust leaks, but does build no boost at all, car is running fine, adjusted the fuel pressure to 43lbs, what could be causing this issue, anybody have any ideas, would appreciate it.
