I was talking about this subject with some friends, and figured I would get the Turbo Buick community's opinion, as I know there are several great minds on here
The question was which would work better on a boosted application: Single Fogger Nozzle in the intake piping, or a Direct port setup? Let's assume the following:
- Vehicle is on good gas (C16)
- Using Methanol Injection
- Making a fair amount of power (800+ hp)
- Advanced EFI (XFI, BS3, Accel Gen7+, etc.)
- Individual Cylinder EGT monitoring
The reason for the question was that by using a single nozzle in the intake pipe, you are reducing intake temps significantly in addition to adding oxygen to the combustion cycle. I was concerned that by using a direct port system, you would lose the benifit of cooling the intake charge. Yes, I know the Methanol does that as well, but the cooling effect of the nitrous must be ten fold (at least) that of the methanol. The trade off of the direct port route being the tunability of individual cylinders.
So, Pro's & Con's:
Single Nozzle:
Pro: Greater reduction in intake temps
Con: Decreased tunability
Direct Port:
Pro: Individual Cylinder tunability
Con: Decreased / No reduction in intake temps
So...
- Am I missing any variables?
- Which is better on a serious boosted application?
Let's talk
- Matt
So, Pro's & Con's:
Single Nozzle:
Direct Port:
So...
Let's talk
- Matt
