Domestic plugs have a lower number to designate a colder plug. Foreign plugs have a higher number to designate a colder plug. Keep in mind that whatever the catalog's number is for a TR plug, that plug is already a step colder than it's non turbo counterpart. Different plugs seem to respond differently than others in terms of ability to pull heat out. An AC plug thats 2 steps colder, will give me more KR than a stock heat range (4) Autolite double platinum plug. There are alot of people using NGK plugs who use a number 2 steps lower, thinking they're 2 steps colder, and wonder why they have to pull so much timing out or run so much fuel to keep KR at bay. They're actually running a really hot plug. I never did like NGK's on any car I had, just like champions, which me and my friends used to call foulmasters.
On my cobra, I was making 600hp with 12psi on a motor with 10:1 compression on 91 pump gas, no alky. And this was with stock heat range, autolite double platinums. Theres something about those autolites that seem to keep knock at bay. Denso iridiums are miracle workers on all forced induction engines. Theres an iridium plug with a .7mm tip, and one with a .4mm tip. There are some people who claim to have had problems with TR's and those plugs, but if adding iridiums caused misfires, then there was something else wrong with that ignition system. The iridium plugs make ignition systems so much more efficient its ridiculous. There are countless people who have gained 50+ hp after switching on forced induction engines...people who had no obvious misfiring or spark blowout, but obviously did. Kenny Duttweiler gained 750hp after switching to iridiums on a turbo'd 1800hp engine. he had the best ignition components on the planet and couldnt cure this blowout issue he was having. he switched over and all the missing hp came back. If you want to get a good plug, get the .4mm tip iridiums. Only problem is that they're 10 bucks a pop, but so what.
