Wow ! nice evo,that must be a little rocket.
If you havn't already decided on a chip, I believe most people on this forum would suggest "Turbo Tweak" for your chip,you can find him here.
http://www.turbotweak.com/ I got one for a car a few months ago that didn't idle that great + was burning rich at idle + it worked wonders for it.
I will make one more suggestion on "Bang for the Buck" mods that doesn't hurt the stock like drivability.
Since you are going to be unhooking your cat converter from your downpipe to put in a 3" high flow cat,you may want to think about getting a 3" downpipe to go with the new high flow cat + do both while it's apart, the 2 together should really work nice,I don't think the bigger down pipe takes away from drivability, or makes it any louder,but is supposed to add good power + helps the turbo spool quicker.
Here is some info on it + a site vendor that sells them.
http://www.kirbanperformance.com/pr..."+Bolt-In+DOWN+PIPE+and+CLAMPS+(2)+#6568.html
One other thing i will point out in case you are not familiar yet, the fuel setups from the factory are pretty weak on these cars,+ even stock cars can benefit from strengthening it, but with a few mods it becomes even more important to "At Least" put a "Hot Wire" on the stock fuel pump, which then gives your stock fuel pump full voltage.(Remember your fuel pump on such a low mile car is probably the original 25 yr old one so you may want to consider the Hot Wire + a hp fuel pump)but i would at least do the Hot Wire which is quick ,cheap,+ easy.
I believe the Hot Wire is just a wire going directly from your alternator to your fuel pump,giving it full juice,which the factory wiring didn't do.
If you have any questions about these items,just ask + people more informed about them can give you more info + tell you the best places to get them etc.You already have a turbo car so i'm sure you know that you don't want your gn to lean out under boost,it gets expensive real quick.
Good Luck with the new GN.
