monte4ever
- Apr 5, 2011
Will the GN fuel level sender read accurately in a Monte Carlo? Also, when running high fuel pressure ( 60+) do you use regular fuel injection hose to connect the sender to the hard lines or is there a way to attach -AN fittings to the sender (preferred)? I want to run a double pumper setup from Racetronix or Reds hot air (whichever one is the best), however these two issues are stopping me from pulling the trigger. I know I can use the sender off the Monte but I like the GN stainless steel construction.
