Intercooled88s
Moderator
- Aug 10, 2004
109 Block $300
std/std crank $325
.010/.010 Turbo crank fresh from the machine show $375
.020/.020 Turbo crank fresh from the machine shop $175
stock 8445 heads needing rebuild $40 a set
84/85 to 86/87 conversion parts(all the original GN parts you need to convert over from 85 to 87) $1400
BRF coded GN transmission 80k $500
BQ coded GN transmission 48k $300
Stock 200 4r tranny pan $35
Oil cooler adaptor with nut $35
Timing cover $25
109 block $300
Turbo crank $300
Turbo rods(2 dot) $40 a set of 6
Turbo flex plate $25
Turbo oil pans $30 each
84-85 stock turbo
84-85 control module $50
84-85 up pipe(stock) $40
84-85 up pipe(after market) $40
84-85 Stock Turbo $200
GN sway bars $30 each
windshield wiper assembly $15
Complete heater box $150
Manual antenna assembly(mast, base and screw) in blackout$40
Non Key locking t-top $90+shipping for the set
GN tail lights with blackout trim $100
Quarter glass with blackout trim $70
3 piece windshield blackout trim $30
3 piece rear window blackout trim$20
Any other black piece e mail me
GN hood $95-$150
86-86 GN plastic inner fenders uncracked $75 each
AC lines $45
Turbo shield $30
Powder coated turboshield(silvery/chrome finish) $60
84-85 GN intake $40
86-87 fuel rail $30
84-85 fuel rail $25
Any year injector harness $30
84-85 valve covers $35
86-87 valve covers $35
cam position sensor just the lower part(no cap) $25
84-85 MAF $45
84-85 turbo adaptor $25
86-87 exhaust manifolds $85(drivers cracked but weldable)
86-87 crossover pipe $45
84-85 crossover pipe $35
84-85 Alt $30
8445 heads $40 a set
84-85 engine wire harness $145
86-87 engine wire harness $175
Any other harness on the car e mail I have them all
Blue dash pad $120
Maroon dash pad $100
Chrome and gray strips on upper door panels $25-$35 each piece depending on condition
I have all the plastic interior pieces for a marroon or grey car with either t-tops or hard top .
Nice grey arm rests $15 for both
Nice blue passenger visor with lighted mirror $25
Gauge surround $35
radio surround $25
Stock GN radio $50
T-TOP trim around the t-tops on the inside of the car in Red, Maroon, or grey , all 6 pieces $100
87 GN steering box $40
E mail me if you need a part not listed Fortune628@aol.com I most likely have it.
or CALL ME at 413 746 9668
I JUST BOUGHT 3 MORE PARTS CARS 2 84 T-TYPES AND 1 86 GN, IF YOU NEED SOMETHING FROM THESE CARS LET ME KNOW.
http://www.freewebs.com/turboparts/engineparts.htm
std/std crank $325
Timing cover $25
109 block $300
Turbo crank $300
84-85 stock turbo
GN hood $95-$150
AC lines $45
Turbo shield $30
84-85 GN intake $40
86-87 fuel rail $30
84-85 fuel rail $25
84-85 MAF $45
84-85 Alt $30
Blue dash pad $120
Gauge surround $35
radio surround $25
Stock GN radio $50
