Rich, Your one of the original B4B guys, you have seen alot come and go, whats your thoughts on all the aftermarket intakes and turbo mods we have come up with lately? do you see us going the right way? or out in left field?
Fair question. Personally,
for me, they are out in left field, so I stay out of them. I look at this board just about every day and comment when I can help & I am sure about what I am saying.
Some wisdom....
- Bang for buck is key. 'Buck" is not just about money, but time as well. Nobody wants to spend money and invest time with little to no return.
- Find the weak point, and then fix that. No sense in putting on a 3" downpipe if it's not a restriction.
- Tuning (optimizing) what you already have is more important than buying new parts.
- Gauges and sensors are important. I believe a knock gauge is a must.
- A factory shop manual is a must also. Don't remove that emissions "junk" until you know exactly what it does - the book will tell you.
- Theory must be proven in the real world. A some point, you have to do it to a running car and take it down the track.
- Bad advice is worse than no advice. (or never take advice from a salesman - I fell for something called a PowerTrax differential locker.)
Fred Carrado ran low 13's on the stock intake and stock style turbo. So I don't believe those are my restrictions. I have his turbo on my car. It's a stock turbo with the housings machined for larger impellers. For my current set up, it's too big and spools slow. Everyone said I needed a higher stall converter - didn't help at all. I'll grow into it one day, but for now, it's a mistake. If I had time, I'd put the stock turbo back on (or maybe a hybrid of the two).
There is no magic bullet on these cars. Alcohol injection is the biggest bang for buck IMO, but no one here is doing it. And no one talks about knock gauges, but that our biggest enemy. Some say they don't "hear" it knocking - if the ESC is working, you will NEVER hear the knocking.
My long block is stock and I still have the ECM controlling the engine. My car ran in the 17's first time at the track. Now I'm knocking on 13's door (the race gas might be cheating
) I don't think it's "fast", but it's not slow. Most of what worked was from trail and error. Many things that people said should have worked didn't.
Running fast on the factory turbo set up is what makes a before black car cool. They aren't supposed to be fast and surprising people is fun. If I were to make extensive changes to the turbo and intake, I'd go to the blow thru setup with a '87 turbo/ exhaust piping and a 4.1 intake.
These engines aren't that difficult and the stock stuff isn't that bad. I have started building a motor for my '82 GN. It will be based on what I have learned from this '83 T Type and it will use as much of the factory stuff as possible. Unfortunately at the rate it's progressing, it might a retirement project.
