jus thought id let you guys know what i was planning for my gn and see what you think. im doin 4 kicker comp 10's in ported boxes with a jbl 600.1 on them. it should slam, which is what im going for gimme your opinions, i think it outa be very tight
Originally posted by Sinister86 jus thought id let you guys know what i was planning for my gn and see what you think. im doin 4 kicker comp 10's in ported boxes with a jbl 600.1 on them. it should slam, which is what im going for gimme your opinions, i think it outa be very tight
I am building 4 10" subs into my GN also but I will have the ports from each chamber feed through the rear deck. With 4 10s, you will have the piston area needed to push alot of air just make sure that your amplifier can feed all 4 with more than enough juice. 4 10" subs fit perfectly across the rear trunk shelf fender well to fender well.
