T Turbo231 Member Joined May 28, 2001 Jul 22, 2006 #1 I just replaced my 200 and can't seem to get it to kick down. I pulled the tv cable out of the trany and the rod seem to be higher out of the housing than the old one by about 1/2 ". the old one was flush with the housing. could it be stuck?
C chris718 Active Member Joined Dec 10, 2002 Jul 23, 2006 #2 tv cable is not tight enough.check this first
T Turbo231 Member Joined May 28, 2001 Jul 23, 2006 #3 what about the rod the the cable is attached to? It seems to be out of the case farther then the out trans by about 1/2"
C chris718 Active Member Joined Dec 10, 2002 Jul 23, 2006 #4 its probably a 700 rod.tighten the cable extra.
