turbo6leon
- Jun 7, 2001
I have my new motor in the car & running but it's not right. It does, however, start right up & sit there running, billowing ton's of raw fuel and smoke. I've set & re-set the cam sensor at *least* a dozen times & nothing changes. It goes closed loop fairly quickly but the 02 mv's stay at .96 with no cross counts. IAC varies from 175 to zero but rpm's don't change with it. Fuel pressure is fine & I've tried 2 different chips. Injectors are used blue tops. It sets no codes here in the garage but it smokes waaaay to much to drive. Do I still have the cam sensor out of whack somehow? The injectors not functioning correctly?? I don't understand why the 02 is inactive. I've inhaled too many fumes & I'm going crazy. What's wrong with it?????
Thanks,
Lee Kline
Thanks,
Lee Kline
