Finally installing a new long block, what else should I replace when the motor is out. I am currently replacing the motor mounts, transmission mount, water pump, thermostat, and I have an F body rad ready to go. What else should I be looking at? I was thinking about a new converter at the same time. If so what stall speed should I use? It has a stock rear, and I want this to be a good daily driver with some time at the track. I am going to need a new chip, I have green stripe injectors and a stock turbo.
Any help is appreciated!
