Here is what I have found since I last posted.
The car has a Hot wire kit for the fuel pump.
Kenne Bell Adjustable fuel pressure regulator (reads 42lbs at idle with the vacuum hose off, 36lbs with it on)
RJC aftermarket PCV Valve
I bought a chip from Turbo Tweak for 91 octane fuel since that is all I can find around here
It has a two piece 3" aftermarket down pipe
I added the Scanmaster and PowerLogger
Installed a new alternator due to a bad bearing
installed a new red top optima battery (old one tested bad and I had to jump start the car every time I wanted to drive it)
Everything else appears to be stock. Except maybe the Turbo... Just left the car show at Fuddruckers in Tulsa and looked at two 87 GN's and both of their turbos say Garrett, mine does not.
I'm going to put a new High Output Coil Pack, Plugs, and Wires on as soon as they show up (ordered from G-Body).
I've also got a new fuel filter to install this weekend and have ordered the Casper's FieldFix ALTERNATOR PLUG-IN.
I will also be doing a battery draw down test this weekend.
Maybe someone can tell me what's wrong by taking a look at the power logger file. For some reason the boost is not reading in the power logger. The aftermarket gauge and dash gauge never go above 15lbs. when under boost. The car is only making about 12 volts even with the new battery and alternator.
I appreciate all of your help.
